RCU Forums - View Single Post - Engine porting
Old 01-24-2008 | 01:50 PM
  #121
JB COMP's Avatar
JB COMP
Default RE: Engine porting
ORIGINAL: supertib
ORIGINAL: JB COMP
my normal files I have will cut the chrome, but it takes a long time. you can get a set of diamon files on ebay for $10
you are not the frist person to say "I wouldn't have tought you where 14" or somthing along those lines
your dreaming if you think normal files will cut the chrome......as well it also takes quite some time to cut even with diamond files...... This is not something to be taken lightly..
I should of known you where going to say that, you're almost so predictable about modding engines and piccos its almost funny. (I mean that in a good way) my files are dual cutting files and they did cut the chrome (not the timing) I was messing around cutting the the bottom of the sleeve below the boost port, and they did cut the chrome, I'll try to get a picture and post.
know they would work for timing since it takes a lot to cut the chrome with these, and they are too big to do timing. basicly they are for outside the sleeve modding only.
