RCU Forums - View Single Post - Engine selection for Nexstar ArF help
Old 01-24-2008 | 04:40 PM
bigtim
My Feedback: (13)
Default RE: Engine selection for Nexstar ArF help
the OS 46AX and 55AX will fit in the supplied engine mount provided in the ARF kit, the iso smooth mount works well,I use one in a sport plane I have.
the OS 46 works fine with the NEXTAR airframe, if you go with a larger engine you going to have to shift the battery and reciever rearward to get the CG to balance since the plane was designed around using the OS 46.
