RE: How to simulate planking on a plywood deck?
hi
i build a 5'pt boat what i did was us a wood burning tool with a sharp point and lay out the lines a us a straight edge rule to burn the lines in two passes looks great ill have to find the picture but try it on some plywood and then put in some cross lines here and there but lay it of frist so you can have even size board on each end i went with 1/2 wide rye
