RCU Forums - View Single Post - Engine selection for Nexstar ArF help
Old 01-25-2008 | 12:07 AM
bigedmustafa's Avatar
bigedmustafa
Default RE: Engine selection for Nexstar ArF help
ORIGINAL: Johnmpa
I've placed a Saito 56 4 Stroke on my Nexstar. You have to use a 12in or less prop for ground clearance, but it works well. Takeoff run is a little longer, but she purrs along and sounds great. It has plenty of power and balances out very similar to the OS 46 engine even though the Saito 56 weighs more (?????). I even used the stock Nexstar engine mount, but you'll have to dremel out the mixture adjuster. Good luck.
The .46 FXi that comes on the Nexstar Select RTF weighs in at just over 17 ounces, the weight of your Saito .56 is around 15.5 ounces with muffler. Most .70 4-strokes weight the same or less than most .46 2-strokes. The Magnum XL .70 RFS is the exception to this rule, it weighs in around 21.2 ounces or so. The O.S. FL-70, Thunder Tiger F-75s, Saito .62A, .72, and .82 all weigh about the same as a .46 ball-bearing 2-stroke.
