RE: Cold weather starting
I would say that you will struggle a bit at those temps. It would help to have a really hot glow igniter. How many amps can your deliver? If its one of those single battery ni-starter types then its not going to do it. Part of the problem is the battery will not perform well at those temps either.
We pattern guys use a glo driver that has some punch to light the fires. The Radio South Pro-driver or the RCATS glow driver. These have larger capacity batteries. Like 2000mah 6-8.4V packs and they step the voltage down and allow the plug to draw really good current like 2-3-4amps if needed. The single battery types just can't keep up unless they are on a fresh charge....and then when its cold well they suffer.
Lighter Fluid. NO in YS engines, Yes in other glow engines. It works, but the petroleum based oil will not be good in the YS engine engines.
A good hot glow starter and a little prime of 30% will be your best bet. They as all glow engines especially 4 strokes will become very stubborn at those temps.
Warm the engine up in your car then take it out and crank it right up...that is another possible solution. Depends on you model.
Then again in the winter when its that cold out, some guys started flying indoor with little electrics.
SMILE
I can't say too much. I just spent the day at the Arizona Electric Festival. There were a bunch of people and it was the Friday group. I suspect it will be darn crowded tomorrow. Then again it was typical Arizona weather, The low was about 40 last night with a little rain early in the morning. Then it was upper 60's for the day.
Troy Newman
Team YS
