RE: Super hawaii help please
OK thanks for that retaobcr, I will move the rudder over.
My CG is very good at 1/3 length from the back of the boat the batterys do sit forward from the motor.
With the brass tube and stuffing tube there is less then a mm of play, and same thing with the stuffing tube and flex shaft, less then a mm of play.
they are not a tight.
I lubed the flexshaft with bearing grease really well last night and that seemed to stop the water from coming in.
QUESTION:
I have the stock plastic adjustable trim tabs, they are a little longer but a little bit skinnier.
Would these be worth using instead of the trim tabs I have on it now?
I would still get some turning fins to use of course!
