RE: How far out on the high speed? (evo 46)
Thats a good place to start. If you can't get the engine started, keep turning the needle in about 1/4 turn at a time until the engine gets started. You're starting it at low speed, so the high speed needle has only a small effect. Once you get it running, its quick to set the high speed needle where it needs to be.
Brad
