How far out on the high speed? (evo 46)
Hey,
Engine in question is an evo 46 or what ever that comes with the alpha 40 trainer.
Had to change the needle valve braket after someone crashed there trainer, helping them put it back togeather now. Iv got it (HS) at 2.5 turns out what would you set it to? (just need to get it so that it runs we will tune from there obvously)
thank you
Steven
thank you
Steven
Thats a good place to start. If you can't get the engine started, keep turning the needle in about 1/4 turn at a time until the engine gets started. You're starting it at low speed, so the high speed needle has only a small effect. Once you get it running, its quick to set the high speed needle where it needs to be.
Brad
Brad
ORIGINAL: bkdavy
Brad
Brad
ORIGINAL: carrellh
it really needs to be started and tuned before he heads out to fly a repaired plane
Steven
Actually the engine comes fairly close out of the box.
If you haven't touched it, leave it as is and start it up.
You'll find that the limiters will either be in the right range or you'll need to turn the HS in just slightly MORE than the limiters permit.
The Evolutions come set up from the factory to run rich.
