RCU Forums - View Single Post - How far out on the high speed? (evo 46)
Old 01-26-2008 | 03:26 PM
Flying freak
Default RE: How far out on the high speed? (evo 46)
ORIGINAL: bkdavy
Thats a good place to start. If you can't get the engine started, keep turning the needle in about 1/4 turn at a time until the engine gets started. You're starting it at low speed, so the high speed needle has only a small effect. Once you get it running, its quick to set the high speed needle where it needs to be.
Brad
ok thank you, Just wanted to make sure it wasnt too hard on him as i may not be there when he flies it and engine problems are not ideal for the beginer
