RCU Forums - View Single Post - FIberglass Mold How to Tutorial
Old 01-26-2008 | 06:09 PM
DocJones199
Default RE: FIberglass Mold How to Tutorial
Moving on with this turorial, PVA is now sprayed onto the plugs and the parting board. The PVA is an excellent barrier between the mold and the plug. I like to spray a coat, let it dry and then re-apply. Applying two coats of PVA can result in lost detail but that is not a concern for me with this project. An additional coat of PVA will ensure an easy release when I de-mold the plugs.
PVA is applied with my spray gun at about 60 psi and a distance of 8 to 12 inches. PVA is cheap and valuable at the same time.
For the molding process I need my air compressor and dump gun along with: tooling gelcoat, fiberglass resin and chopped mat, MEKP, rubber gloves, disposable brushes and a respirator or fume mask.
I begin by applying black tooling gelcoat with a dump gun at about 80 psi. I make sure to keep the gun close to my work because gelcoat makes a huge mess if it gets on something other than your project. I lay down a nice thick layer of gelcoat making sure to get good coverage around the base where the plug meets the board.
