ORIGINAL: davido666
My warhead has been running great I have a few upgrades like the metal servo saver and metal steering. Upgrade the steering for sharper turning. Metal spur gear and hardened clutch bell. I put in an axial 32 but my old super tiger was running great and good temps on it. It just wanted to put in a different motor for the hell of it. Bigger and softer tires to cushion the landings. The truck must have an inline fuel filter put in. There is no filter built in the tank so it needs a fitler to keep the dirt out of the engine. I still have a lot of plastic because it is lighter than the aluminum which means it flies further.[>:]
Ok this also brings up a great question. What is the best or biggest engine to put in it? Can the evo be set up from stock with stock everything to pull the front end up if you choose to?
