RE: Sig Hog Bipe
smashmaster, I'm not an expert but I think any of that type wood glue works fine. As long as you hold it in place till it dries. some use ca but you have to be able to work fast and have a system to hold it all down during the set time. One thing I've found is to tape or rubber band sheeting to the curved surface after wetting it with alcohol or amonia or water and let dry to shape. Goes a long way in helping to hold down without splitting and where it is supposed to be glued. The hog bipe suggest that in sheeting the turtle deck on the fuse. Just do a dry run to be sure you can get it where you want it before gluing and you should be fine.
