RE: need input about the Walkera Dragonfly 36
Looks good,
You will find that it's grossly underpowered with the brushed motor and stock battery. Probably will barely hover, But at least it is adjusted and setup as they are not from the factory.
Add a brushless motor and a 1800mah or bigger lipo and it will be a good flyer. You will be amazed by how much more stable it is over your cp2 and tail motors are the DEVIL.[:@]
