ORIGINAL: Dr1Driver
Be sure your ATV is set to 100% both ways. A shorter servo arm will give you more movement at the carburetor.
Dr.1
A shorter servo arm will give less movement at the carb and more at the servo. His problem is too much movement at the throttle.
