 Throttle Curves? >
Throttle Curves?
Throttle Curves?
Old 01-27-2008 | 03:55 PM
Default Throttle Curves?
hi all. trying to set up the throttle on my plane. what im trying to do is set up the throttle so that , naturally, all the way down is closed and vice versa. trouble is i go from throttle shut on the stick to full throttl at only half stick. i want full throttle to be with the stick all the way up. its getting confusing now so i thought id ask.
Its a futaba 6ex system.
cheers all
Old 01-27-2008 | 04:03 PM
Default RE: Throttle Curves?
G'day Mate,
Check my PM, it may help.
Old 01-27-2008 | 04:05 PM
My Feedback: (7)
You are usig a too long servo arm. Use a shorter one.
Old 01-27-2008 | 04:48 PM
Be sure your ATV is set to 100% both ways. A shorter servo arm will give you more movement at the carburetor.
Dr.1
Old 01-27-2008 | 05:16 PM
acarter's Avatar
You either need to increase the size of your servo horn or decrease the size of your carb horn. Most of the time you don't need a new horn just simply move the control rod to the farthest out or most inner hole depending on the horn.
Austin
Old 01-27-2008 | 05:31 PM
Moderator
All you have to do is change the ATV on your radio. You can also make the change mechanically by moving your pushrod in a hole or two on the horn.
Old 01-27-2008 | 05:40 PM
Missileman's Avatar
ALWAYS, get in the habit of making mechanical adjustments and only resort to radio adjustments like ATV as a last resort or at least just for fine tuning.
Move your connecting rod out farther on your servo.
Old 01-27-2008 | 06:27 PM
My Feedback: (7)
ORIGINAL: Dr1Driver
Dr.1
A shorter servo arm will give less movement at the carb and more at the servo. His problem is too much movement at the throttle.
Old 01-27-2008 | 09:01 PM
Missileman's Avatar
ORIGINAL: Jim Dines
ORIGINAL: Dr1Driver
Dr.1
I misread his post, yes you want to move to a hole closer in on your servo.
If you are in the 3rd hole out move it to the 2nd hole and see if that helps.
Old 01-27-2008 | 09:09 PM
acarter's Avatar
ORIGINAL: Missileman
ORIGINAL: Jim Dines
ORIGINAL: Dr1Driver
Dr.1
If you want more movement at the carb you need to put the control horn farther out on the servo horn.
Austin
Old 01-27-2008 | 10:16 PM
r2champion's Avatar
I think he is officially more confused now than he was before. Now, you need less throw at the carb. To do this, move your linkage In towards the center of the servo 1 hole. If this isn't enough, go in 1 more. The same can be done at the carb linkage, but in the opposite direction. I think this is causing the confusion. Moving the linkage OUT at the throttle barrel will also gove less throw. Hope this helps.
