Axe CP Main Blade Installation
Hello All:
I broke both blade grips and replace them but here is my problem. The heli works but the blade grips are 180 degrees off in that the bottom where the nut goes is on top and I have to enter the screw from the bottom. The links does not work otherwise but it flies I just don't understand. I know the screw should enter from on top goes through the main rotor blade and is secured by the nut at the under side of the blade grip. Can anyone tell me what I did wrong when I replace both blade grips and how to fix it? Thanks - Busha
