I can't belive it !!!
Thanks for the info guy's ! I read inn the direction's that the cg inn the manual is wrong and give's another cg. That might be why it was squrliy.
No i am not moding this plane. I like it just the way it is. I do love the way its built. And yes the hardware is a joke!
Not sure about needing more weight up front. I just got the radio in and checked balance. Tank on cg and using stock hardware the cg landed about 1/8 inch behind the starting cg! It is a little on the heavy side at 5lb 12oz.
Just need to clean the wiring up and the wait for good weather. Its supposta be crapy this week end.
