DA-100 Ignition Battery
Well if the battery starts to get too low on a 6V you will still have over 5.5 volts roughly. If a 4.8 gets to low it might be around 4.4 volts and then the engine dies.
I can't verify that w/ experience b/c I use a 6 volt battery and check it before every flight. But, in theory it might help.
