RCU Forums - View Single Post - No spark, what gives?
Old 04-16-2003 | 04:32 AM
bn120
Default No spark, what gives?
If you are using the same plug from when you dropped it, it might have a internal crack and shorting, try a new plug just use one from anything to check for spark or use a screwdriver in the boot and hold it close to the engine and see if you get a spark with out a plug but most times you dork a plug it will short internaly.
Darin
