RE: Which one to go for
Munin
The MVVS .49 engine is delivered in side exhaust configuration.
The cylinder assembly bolts into the crankcase. Crankcase and cylinder are not unitary like most 2 stroke engines.
If you want the engine to be rear exhaust, you unbolt the cylinder and head, and and turn the cylinder clockwise 45 degrees. Gently remove and re-align the head, replace the bolts and your done.
MVVS recommend that you select your preferred exhaust orientation before first start-up, to avoid upsetting piston and liner fit.
