ORIGINAL: nemesis4u
ERIK,
AS KSOC POINTED OUT and to also clarify....
IF YOU ARE RUNNING THE TAMIYA TANKS STRAIGHT OUT OF THE BOX WITHOUT ANY ADDITIONAL FUNCTIONS you only need a 4 channel radio.... I run ALL my Tamiya Tanks past and present on the reliable Futaba 4 channel radio on surface frequencies listed here:
http://www3.towerhobbies.com/cgi-bin...=LXEFJ4**&P=ML
Surface: 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89 and 90
You use the trim tabs to activate the machine gun and to fire the main gun... IT is all plug and play with the TAMIYA BRAND... IT IS EASY.. No worries... and we are all here to support you and encourage you through your assembly!!!!
I was stating the yes it normally comes with 4 servos ( I use them in my R/C WARBIRDS) ... So later if you wanted to use them for something custom you could...but they are NOT NEEDED for a stock full function TAMIYA TANK!
CHEERS!
-TOMAS
TEXAS ARMOR ASSOCIATION OFFICER
www.bomberfieldusa.com
www.texasarmor.com
www.vqwarbirds.com
[email protected]
[email protected]
