ORIGINAL: Jim T
ORIGINAL: alex7403
I found this picture here in RCU, its from an astro hog build
What do you think about this aileron servo setup compare to:
1) one servo in the middle.
2) Two servos, one inside each wing
I figured its easy for me now to change the wing into this.
Alex
The original Astro Hog just used a single servo where your picture shows 2. This definitely makes it easier to set up the ailerons using a modern computer radio with more than 4 channels.
Jim
Actually that's the Sig kit. The orginal Astro Hog used a single servo with pushrods that went to bell cranks in the wing with rods that went out to the barndoor ailerons.
Hogflyer
