RE: just got my first plane!!!
If it's not 100% necessary don't use the ACT, sounds like you kinda got the hang of it. I'm pretty sure that you can keep it off until you get in trouble, then you can turn it on and it will correct the plane (but I may be wrong). Once you feel that you don't need it at all you can remove the system all together and save some weight.
Austin
