RCU Forums - View Single Post - just got my first plane!!!
Old 02-02-2008 | 04:13 PM
Pilot Sofer
Default RE: just got my first plane!!!
On your first flight, you should check that everything is in a proper manner. Before you'r first flight, here is what you do:
1. Range test it.
2. Check all clevises that they are properly placed on the control horn.
3. Tighten all loose screws, nuts, and bolts.
4. Check that the propeller nut is tight.
5. fully charge the battery.
6. Read all flying instructions.
7. fly on days with calm winds( The best time to fly is early in the morning because there is not a lot of wind).
8. Wear a hat and sunglasses.
9. use little stick movement when you are flying.
10. Fly safe, and have FUN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
