yup, very happy with servos, 1313 is plenty for a truggy, very fast too. it took me a couple gallons to get used to the speed of the servo and not catch an inside pipe every turn. the stock tires are not good on loose dirt, ok on a damp thicker track. the stock pipe is very good on the sts so far also.
the first problem is that when i am turning into corners there isnt to much turning the front end just slides , Is this something to do with my shocks / springs ? Its not my tyres and im not going 40 mph into corners exspecting it to grip. I am using a futuba 3050 servo .
too much front brake, adjust the setscrew so they slow down but don't lock in the turns.
The second is that the arms actually keep undoing
need to clarify what arms and where they are undoing.
And the final problem is to do with my engine ..... Its a go 21 5port and in the race i was running it rich as it was only on its 8th tank .... But all of a sudden it leaned it self of and by the time i got to the pitlanes it was reading 378 degrees and the colour of the head and pipe had changed ..... Why did it all of a sudden lean it self off ? any ideas?
sounds like an air leak, check with short piece of fuel line attatched to carb. plug carb opening and exhaust (with pipe off) and listen for air when you blow in hose. spray soapy water or simple green where you hear it and watch for bubbles. no bubbles then problem with fuel lines or tank. good luck.
