RCU Forums - View Single Post - Axe CP Main Blade Installation
Old 02-02-2008 | 07:33 PM
Rotor13B
Default RE: Axe CP Main Blade Installation
You can fit the nut and bolt on the right way if you want to. If you angle the nut in the in the hole and then push it in it will stay in even when the lag bolt is removed through the top. Both my Axes are setup this way.
