RCU Forums - View Single Post - Precision Aerobatics announces electric extra 260
Old 02-02-2008 | 09:31 PM
aflipz
My Feedback: (10)
Default Precision Aerobatics announces electric extra 260
Quoting PA themselves from a thread on RCG:
In spite of rising cost, the price will be same as the Katana MD, $189.99
Specifications
Wingspan 1219mm (48"
Length 1094mm (43"
Wing area 490sq in
AUW: 955g / 33.7oz
Wing loading: 9.9oz/sq.ft
Motor: PA Thrust 30
ESC: PA Quantum 40
Servos: 4 Micro servos 1.6kg/cm torque
Lipo pack: PA 2,200mAh 11.1V
Prop: APC 12x6 E or 13x6.5 E
Our Slogan for the new PA Extra 260 is “Breaking All the Rules” – which is literally what we achieved in the design of this model.
We approached the new design with the short “wish-list” you guys posted on RCG and with FiberFusion™ construction technology under our belt. The result is an amazing aircraft designed for unlimited aerobatic performance with a level of precision demanded by today’s Freestyle competitions.
While the Extra is larger than the PA Katana MD and features fully air-foiled tail section it weighs the same as the Katana MD! This means the new 260 is now the lightest model in its size category, yet is it one of the robust models available on the market today.
Being this light also mean you can power the PA Extra 260 by the same lightweight 30 size iPAs setup as the Katana MD. (If you don’t have the set up yet – check the special discounts on our website – not only you save $35 on the combo shipping is FREE worldwide).
Similar to the Katana MD, the new PA 260 ailerons fit into the wing trailing edge tunnels and are glued and pre-aligned in the factory.
The PA Extra 260 excels in all tumbling manoeuvers. Violent walls, snaps rolls, flat spins (representative of full-scale aircraft) are just some of the high-speed, high-energy maneuvers the Extra 260 is capable of performing.
On the post-stall extreme freestyle end, the Extra 260 is fully capable of executing excellent, well balanced rolling harriers (extremely slow and persistent) and slow stable harriers (both upright and inverted) with no wing rocking.
Elevators are extremely stable (allowing long elevators all the way down to a spot landing) and harrier turns are tight and stable. Transitions into high Alpha flight are extremely smooth and stable. The 260 also Knife Edges, with the accuracy to perform KE circuits adds a further dimension of precision to the overall flight performance.
So if you demand precision flying with unrestricted freestyle and 3D agility, the PA Extra 260 is the ultimate no-holds-barred, high performance aerobatics machine that delivers.
End quote, needless to say i am pretty excited about this one.
I want a green one, how about you?
ID:	868494   Click image for larger version
ID:	868495   Click image for larger version
ID:	868496   Click image for larger version
