RE: CX2 problem
found my problem. My inner shaft, with the upper blue hub is bent. Is there any thread or post on the replacement of this shaft???? If not, any quick way to swap it????? how do you get the top blue hub off the shaft????? I loosened the set screw and it still would not come off
Thanks 871
