E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
CX2 problem
Old 02-01-2008 | 08:49 PM
show871's Avatar
Default CX2 problem
I have this cx2 (got it used) and the thing wil hover and lift for the first minute....then I am wide open and max out @ 3-4 inches of the ground for a few minutes after that. I have tried a new battery, and it has a bit more lift at first, but then does the same thing. What should I look for and try, to fix my mini chopper?????????????????????????
Old 02-01-2008 | 08:59 PM
Default RE: CX2 problem
The brushes on the motors might be wearing out. It probably isn't the 4 in 1 or 3 in 1 depending on what you have. Thats all I can think of. Some of the other CX2 flyer's might have a better idea. New motors would probably be one of the cheaper ideas to go with.
Old 02-01-2008 | 09:17 PM
Does everything turn freely? The 4 in 1 is the LAST thing I would suspect. Was this after a crash? What have You replaced?
If You forgot the step washer (or put it in upside down) or got the retaining collar too tight, that will certainly do it. Check for binding, and let Us know.
Gary.
Old 02-01-2008 | 09:26 PM
Either the charger is junk, or the motors are caput.
Old 02-01-2008 | 11:49 PM
show871's Avatar
everything spins freely, I lubed the bb too. I am using the eflite charger........it take 1.5 hrs to charge back up.
How many runs does it take to start wearing the stock motors out????????
I will try new motors........should I just go stock, or go with something better???????????
Thanks 871
Old 02-02-2008 | 03:18 AM
eat2muchrice's Avatar
Do a few test for me.
1. Check your battery to make sure that its balanced and charged at 4.2v per cell 8.4 total.
2. Check your blades, test, boil, blance and track.
3. Check your gearmesh.
Cheap Battery Test and Fix
http://www.rcuniverse.com/forum/m_6970199/tm.htm
Warped blade test
http://youtube.com/watch?v=_7PwNTXOWMs
Blade boil fix
http://youtube.com/watch?v=RmNv8OlG6GQ
Gear Mesh Guide
http://www.rcheli411.com/pages/howto.php?howto=7&page=2
If thats not your problem then test your 3-1 or 4-1, and replace the bearings. If you still have issues then try new motors. Please keep us posted.
Heres more for you.
Tips/Repair/Guides/Mods Links
http://www.rcuniverse.com/forum/m_68...tm.htm#6821632
Old 02-02-2008 | 11:08 AM
show871's Avatar
blades are good, batts are good.
I did notice while both rotors spin pretty freeley, the top spins twice as easy as the bottom. is this normal? A finger flip on the bottom I get a half rotation, a flip on top about the same force I get a full rotation.
thanks 871
Old 02-02-2008 | 01:41 PM
Ok. Then it does seem like either gearmesh, bushing or the motors. Try bushing first (cheapest) then motors. Most everyone in here will recommend xtreme's 180 .
One more thing I forgot to mention.
Check your locking collar under the swashplate to make sure that its not down to tight. give it 1/2mm free play. Same with your upper hub.
Old 02-02-2008 | 11:17 PM
show871's Avatar
found my problem. My inner shaft, with the upper blue hub is bent. Is there any thread or post on the replacement of this shaft???? If not, any quick way to swap it????? how do you get the top blue hub off the shaft????? I loosened the set screw and it still would not come off
Thanks 871
Old 02-03-2008 | 02:51 AM
Quattro1975’s Bents Shaft Repair
http://www.rcuniverse.com/forum/m_6791546/tm.htm
Old 02-03-2008 | 08:53 AM
ORIGINAL: show871
Thanks 871
Naw, leave the blue head alone, and pull the gear off the bottom instead.
