ORIGINAL: kx_maduk
hi guys , I am having some major issues with my hyper st ,
PROBLEM 1: the first problem is that when i am turning into corners there isnt to much turning the front end just slides , Is this something to do with my shocks / springs ? Its not my tyres and im not going 40 mph into corners exspecting it to grip. I am using a futuba 3050 servo ...
PROBLEM 2: ...And the final problem is to do with my engine ..... Its a go 21 5port and in the race i was running it rich as it was only on its 8th tank .... But all of a sudden it leaned it self of and by the time i got to the pitlanes it was reading 378 degrees and the colour of the head and pipe had changed ..... Why did it all of a sudden lean it self off ? any ideas?
kxmaduk
Problem 1: Try rebalancing the fluids in your differentials. Something like 10K center, 3K front, 5k rear.
Problem 2: Sounds like an air leak to me since it WAS running fine. Check for airleaks in your fuel tubing, tank, carb area, and backplate.
Good luck!
