RCU Forums - View Single Post - LRP pullstart to rotostart
Old 02-04-2008 | 10:23 AM
Ingen28
Default RE: LRP pullstart to rotostart
some drills have way too much torque for a starting system! if you use one set the clutch setting pretty low so that if you flood the engine you will not destroy your connecting rod. Better to air on the side of caution on that one....that being said i use a drill all the time [:-]
