Saito 100 No muffler preasure
I have a saito FA-100 that I have had to rebuild with new pushrods due to crash damage. I have checked the compression and the timing is spot on. Everything seems fine so try to prime the motor before I start it. For some reason the motor will not prime and I am not getting enough muffler presure to feed the fuel from the tank.
Checked the tank and connections and pipes just cant get the motor to provide the fuel through muffler presure. Primed the motor manually with a little fuel and the motor fires and runs for a second no problem then cuts through no fuel. I cannot see ant air leaks anywhere.
Can anyone help???
Thanks TB
