RCU Forums - View Single Post - Brent Good Custom Airframes 50cc Yak 54
Old 02-04-2008 | 06:43 PM
  #124
Stick Bender's Avatar
Stick Bender
Default RE: Brent Good Custom Airframes 50cc Yak 54
I've got the firewall epoxied to the side rails, the top and bottom are just sitting on there. I will glue them after I get the throttle linkage setup and figure out where my batteries are going to end up. The 1/4" birch square stock will come after that.
The gas tank is ready and tied where I think the CG will be, it just needs a fuel and vent line. The throttle servo is mounted.
I put the pull/pull tray where I think I want it, I just want to make sure I'm forward of what's recommended. (I have some extra weight on my tail)
Some pictures of the bevel/taper at the rear of the cheek.
And I got a hole saw set Saturday, it's got 5",4",3.5",3" all the way down to 3/4"
Tonight I put the servo pockets in the wings, I will bring my propane torch home with me tomorrow to bore the servo lead holes.
ID:	870058   Click image for larger version
ID:	870059   Click image for larger version
ID:	870060   Click image for larger version
ID:	870061   Click image for larger version
