RE: Hinges ca or not to ca..
The amount of control travel is really the determining factor. If you are planning on doing a lot of 3D with 45 degrees of travel and constant surface movement, CA hinges will not hold up. If you are sport flying that Katana using normal control throws and minimal surface movement, the CA hinges will last forever.
Jim
