RCU Forums - View Single Post - Falcon 3d question
Old 02-04-2008 | 10:23 PM
gnd2
Default RE: Falcon 3d question
Mechanical CCPM and electronic CCPM. Mechanical CCPM has a "elevator" servo, "aileron" servo and collective pitch servo. The elevator and aileron servos are connected to the swash at 90 degrees and the three functions are "mixed" to the swash plate though mechanical levers in the heli.
Electronic CCPM has all three servos connected to the swash (either directly or indirectly through levers) at 90 or 120 degrees (evenly spaced) and two or three servos may move at once for a single function rather than having a single servo for each function. For example, for elevator movement all three servos in a 120 degree system move together to tilt the swash plate forward or backward.
Here's a pretty good explanation:
http://www.iroquois.free-online.co.uk/ccpm.htm
I'm not even sure if the Falcon is CCPM at all. In the pictures I've been able to find I can't see how/if the collective is mixed with the cyclic controls, or if it's separate. If it is CCPM, it's mechanical, not electric.
