Go Back  RCU Forums > RC Helicopters > Electric RC Helis
 Falcon 3d question >
Falcon 3d question
Electric RC Helis Discuss electric rc heli's such as the Piccolo, Logo 10, Logo 20, Hornet, Eco.
Falcon 3d question
Old 02-03-2008 | 03:11 PM
Default Falcon 3d question
is the falcon 3d a 400 sized heli
Old 02-03-2008 | 04:35 PM
Default RE: Falcon 3d question
yes
Old 02-03-2008 | 06:40 PM
thank u
Old 02-03-2008 | 06:42 PM
would it be posiabel to carry those electronics over to a t-rex 450?
Old 02-03-2008 | 08:04 PM
no the trex and the falcon use diffarent types of ccpm ( collective)
Old 02-04-2008 | 08:18 AM
The Hedgehog's Avatar
And trust me you won't want to use the falcon's electronics in a T-rex even if they did work, they are more suited for RTF work.
Old 02-04-2008 | 09:47 PM
My Feedback: (16)
How do you determine what kind of CCPM a heli has, and what are the different kinds ?
Don
Old 02-04-2008 | 10:23 PM
Mechanical CCPM and electronic CCPM. Mechanical CCPM has a "elevator" servo, "aileron" servo and collective pitch servo. The elevator and aileron servos are connected to the swash at 90 degrees and the three functions are "mixed" to the swash plate though mechanical levers in the heli.
Electronic CCPM has all three servos connected to the swash (either directly or indirectly through levers) at 90 or 120 degrees (evenly spaced) and two or three servos may move at once for a single function rather than having a single servo for each function. For example, for elevator movement all three servos in a 120 degree system move together to tilt the swash plate forward or backward.
Here's a pretty good explanation:
http://www.iroquois.free-online.co.uk/ccpm.htm
I'm not even sure if the Falcon is CCPM at all. In the pictures I've been able to find I can't see how/if the collective is mixed with the cyclic controls, or if it's separate. If it is CCPM, it's mechanical, not electric.
Old 02-04-2008 | 10:59 PM
it's mechanical ccpm... which is why the co-pilot CP4 works with it and not the eCCPM helis... I was looking at teh falcon for a while.. even read the HUGE thread here and at rcgroups about the falcon... then decided I really didn't want it.. just ordered a BlackHawk 450SE from Ka-Planes.com it should be here this week
