RE: Cutting with thread
Wacky is right. The thread gets hot and actually melts the plastic as you saw away. Be ready to break a lot of thread. Once you have the hatch cut, use a small drill bit in a pin vice and drill a hole through the hinges, then insert a sewing pin to create a working hinge.
