Cutting with thread
MD
I believe in the FAQ section there was a post about cutting out hatches with thread but the link no longer works. Can anyone elaborate for me how this works and or update the link since it was originally a utube video and seeing is worth a mess of explanation!
John
John
ON, CANADA
Wacky is right. The thread gets hot and actually melts the plastic as you saw away. Be ready to break a lot of thread. Once you have the hatch cut, use a small drill bit in a pin vice and drill a hole through the hinges, then insert a sewing pin to create a working hinge.
You want to use a thread that has either nylon or rayon in it. Go to a fabric store and tell them what you want the thread for, thats what i did and i don't have any breakage, and it cuts alot faster than normal sotton thread.
CA
ORIGINAL: OliverLove
