RE: Byron Wedell Williams Racer Build
Work and some good flying weather got in the way of building [8D]
Got the leading and trailing edges on then on to the wing tips. The tips and doublers went together fast and I did both at the same time. Gluing the tip on took some care to be sure it was perpendicular to rib 7. Filler blocks added and ribs on the top and bottom.
Sanding everything to shape took some time. I use the masking tape to protect the cap strips while forming the new areas. A razor plane and sanding have the leading edge looking good.
