RCU Forums - View Single Post - Byron Wedell Williams Racer Build
Old 02-05-2008 | 11:01 PM
Rocketman612's Avatar
Rocketman612
My Feedback: (85)
Default RE: Byron Wedell Williams Racer Build
The flying wire mounts left a lot to be desired as I want to use Proctor Flying Wires on this build. The anchor is only 1/4 in spruce and I didn't think that would hold up to the vibration of a G62 over time. I used 1/2 in hardwood instead. Also I added a balsa doubler at the mounting site so the block is glued along it's whole length. The blocks were sanded to the level of the cap strips.
Have decided on Futaba S9001 servos http://www.servocity.com/html/s9001_...l_bearing.html for the Ailerons and likely for the Rudder and Elevator halves as well based on Gremlin Castle and derjager's recommendations.
ID:	871181   Click image for larger version
ID:	871182   Click image for larger version
ID:	871183   Click image for larger version
