RCU Forums - View Single Post - Digital Servos for Blade CX2
Old 02-06-2008 | 12:32 PM
dribbe's Avatar
dribbe
Default RE: Digital Servos for Blade CX2
ORIGINAL: HELINTX
Has anyone tried Spektrum's sub micro digital servos ? Also what is that plastic around the servos for? It is on my CX2's servos as well. Thanks Here is the link: http://www.rchover.com/inc/sdetail/122861
The plastic is to hold the case together. To save weight, there are no screws.
The SPM S60's will mount and work (they may need to be reversed).
I wouldn't expect much performance difference.... as the EFL S60's are also digital servos (The servos amps are different).
The travel of the servos maybe a little different. The SPM servos may be a little less if you don't reprogram them.
Also, be aware of the fact that the CX2 is setup with standard connecters, not micro JST's.
Have fun,
David
