RCU Forums - View Single Post - Fuel Tubing, Where does it go?
Old 02-07-2008 | 05:11 PM
The Real Dogman's Avatar
The Real Dogman
Default RE: Fuel Tubing, Where does it go?
ORIGINAL: forevernitro75
if you would like to shorten your fuel lines that is ok you dont have to worry about heating issues with the fuel line touching the cooling head or the engine block the (1)fuel line will hold up to the heat (if you engine gets that hot you have a problem) (2)to keep the engine from stalling "when" you flip over just tie a loose square knot in the return fuel line ie the one that goes from the tank to the exhaust.
also by (3)shortening the fuel line your engine may be easier to start / tune because the fuel has a shorter distance to travel from the tank and you dont have to worry about your engine over heating just because you shortened the fuel line ...hope this helps
1. Its not the fuel line that is the worry its the fuel heating up and vaporizing in the line(Vapor lock/air bubbles)
2. When you tie a loose knot or restrict the pressure to the tank you are effectively restricting fuel flow to the carb as the line from the exhaust nipple to the tank provides needed pressure to supply the carb.
3. If your engine is tuned properly you wont need worry about how hard it starts, it will start on the first or second pull.
Point is you dont need to "jerry" rig it to make it run well. Just tune it properly!!!
