Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > CEN Racing
 Fuel Tubing, Where does it go? >
CEN Racing This forum is to discuss all CEN Racing products.
Old 08-16-2007 | 07:11 PM
Default Fuel Tubing, Where does it go?
Hi everyone,
Thank you in advance for responding to my post:
As many of you already know the fuel tubing on the Martix CL-1 RTR Buggy is quite long. I would like to shorten it...re-route it differently. I was thinking of bringing it between the Engine Head and the fuel filter over the carborator, but I'm worried about heating issues from the engine on the tubing.
What do you all think? Any ideas of rerouting the fuel lines making for a shorter flow would be greatly appreciated.
Thanks!
Old 08-16-2007 | 07:58 PM
The Real Dogman's Avatar
Default RE: Fuel Tubing, Where does it go?
I'm not sure I would recommend shortening the fuel line. When your buggy flips(I said "when" not "if") you will have more fuel in the lines to keep it running longer while the pickup tube in the tank is out of the fuel in the inverted tank. That will give you more time to get to it or make it less likely to die while waiting for the turn marshall to get to it. But of course excessive heat does not help your fuel line or fuel....
Have fun and good luck!!!
Old 08-16-2007 | 08:17 PM
Thanks Dogman. That's most likely the right answer. I didn't do it. Was just contemplating :-)
Old 02-06-2008 | 11:59 PM
this is how I ran my fuel line.
Old 02-07-2008 | 04:09 PM
if you would like to shorten your fuel lines that is ok you dont have to worry about heating issues with the fuel line touching the cooling head or the engine block the fuel line will hold up to the heat (if you engine gets that hot you have a problem) to keep the engine from stalling "when" you flip over just tie a loose square knot in the return fuel line ie the one that goes from the tank to the exhaust.
also by shortening the fuel line your engine may be easier to start / tune because the fuel has a shorter distance to travel from the tank and you dont have to worry about your engine over heating just because you shortened the fuel line ...hope this helps
Old 02-07-2008 | 05:11 PM
ORIGINAL: forevernitro75
if you would like to shorten your fuel lines that is ok you dont have to worry about heating issues with the fuel line touching the cooling head or the engine block the (1)fuel line will hold up to the heat (if you engine gets that hot you have a problem) (2)to keep the engine from stalling "when" you flip over just tie a loose square knot in the return fuel line ie the one that goes from the tank to the exhaust.
also by (3)shortening the fuel line your engine may be easier to start / tune because the fuel has a shorter distance to travel from the tank and you dont have to worry about your engine over heating just because you shortened the fuel line ...hope this helps
1. Its not the fuel line that is the worry its the fuel heating up and vaporizing in the line(Vapor lock/air bubbles)
2. When you tie a loose knot or restrict the pressure to the tank you are effectively restricting fuel flow to the carb as the line from the exhaust nipple to the tank provides needed pressure to supply the carb.
3. If your engine is tuned properly you wont need worry about how hard it starts, it will start on the first or second pull.
Point is you dont need to "jerry" rig it to make it run well. Just tune it properly!!!
Old 02-07-2008 | 05:19 PM
oh sorry i was just passing on a tip someone gave to me and i use it and it works good so i thought i would pass it on didnt realise it wasnt a good thing to do i learned something new today thanks realdogman and tree1 sorry for any bad info i retract my previous statement
