RCU Forums - View Single Post - CX and Lama so different?
Old 02-07-2008 | 10:18 PM
Jollidude
My Feedback: (39)
Default RE: CX and Lama so different?
I have both helis and there is a noticeable difference between the two. The CX2 is much more responsive than the Lama, you can fly it a lot more aggressively. In addition if you want to go forward with the Lama it also tends to go left at the same time. You have to have to push the stick forward and to the right to keep it going straight. The CX2 does not do this. Perhaps I need to adjust the Lama's servo linkages. Both machines are stock, out of the box. No modifications have been done to either. The Lama feels very sluggish in comparison with the Blade and the maximum forward speed is less as well. The CX2 is more expensive , but it is the better, by far of the two.
Cheers!
Jollidude
