RE: silly putty
you take the diff housing apart, you put the silly putty in the diff with the spyder gears, not the main housing with the pinion and ring gear. what it does is make it a locked posi, this way the 2 wheels grab evently instead of limited slip, will wheelie better with 2 wheels grabbing equally.
