RCU Forums - View Single Post - Sig Hog Bipe - Build Thread
Old 02-10-2008 | 10:38 AM
  #113
chashint
Default RE: Sig Hog Bipe
ORIGINAL: MasterAlex
I am currently putting in the servo rails on the bottom wings - I'll likely post some progress pics later this evening. Getting close to putting the wings together.
-MA
Another mistake I made on the bottom wing was the center section trailing edge (Yeah I make plenty of errors). It can be installed upside down so eyeball it and make sure the top side looks right to follow the contour of the wing.
Also if it is thicker than the wing align the top edges so you will be removing material from the bottom side.
This will make fitting it in the wing saddle much easier.
