RE: Quick Muffler Question
Just removing the end screw may not loosen it up. The assembly is held together by a long threaded screw that extends all the way through the muffler. So if you loosen the screw, then loosen the long screw (on the opposite end of the muffler from the exhaust stinger), it will turn. As W8YE says, tighten it up when hot.
Cheers,
Chip
