Quick Muffler Question
Old 02-09-2008 | 07:37 PM
Mav-Ric's Avatar
My Feedback: (10)
Default Quick Muffler Question
Hello all:
I have just purchased a Hanger 9 Pulse XT 40 with the Evolution .46 NT engine. As I was running a tank of fuel through it today to break it in, I noticed that the exhaust end of the muffler rotated and so instead of the fuel spitting off to the side of the airplane, it was spitting right on it. Now I know the plane is going to get fuel on it regardless, but not as much as if the exhaust was turned outward.
Now, I'm not big on building planes and messing with engine stuff - I just fly them [>:] But my question is, how do I rotate it back? You would think that it must have been loose in order for it to rotate, but I tried to rotate it back, and it was as if it was stuck in place. Is this a matter of just loosening up the screw on the back of the muffler and resetting the exhaust, and then tigtening it back down?
I would like to maiden this plane tomorrow, but I don't know if this affects the motor running at all, so I want to be safe and get your imput on the situation.
Mav-Rick
Old 02-09-2008 | 07:40 PM
w8ye's Avatar
My Feedback: (16)
Default RE: Quick Muffler Question
When it gets hot it gets loose
You may have to warm it up to get it back in position.
Tighten it while hot
Old 02-09-2008 | 10:34 PM
Flyboy Dave's Avatar
My Feedback: (21)
....or, if it won't stay put....install a short, fat, pop rivet in the seam so it can't turn....
....end of problem.
FBD.
Old 02-10-2008 | 11:43 AM
Just removing the end screw may not loosen it up. The assembly is held together by a long threaded screw that extends all the way through the muffler. So if you loosen the screw, then loosen the long screw (on the opposite end of the muffler from the exhaust stinger), it will turn. As W8YE says, tighten it up when hot.
Cheers,
Chip
