RE: fuel ? for TT pro 46
low speed adjustment-idle is a tad rich,squeeze fuel line,engine should be adjusted to speed up slightly at low,if speeds up a lot engine is to rich,if engines dies fast ,engine is to lean,after setting recheck high speed adj.using same method,engine should speed up 300 /400 rpm
