RCU Forums - View Single Post - Nitro models pusher Bobcat?
Old 02-10-2008 | 06:34 PM
  #2892
opjose's Avatar
opjose
Default RE: Nitro models pusher Bobcat?
ORIGINAL: Markcp
I have one these setup for EDF, I have not flown it yet. I modified the back of the fuse to improve airflow to the fan. It is a Hoaye 4" fan with a Hacker outrunner running on 10s. turns the fan at 26,000 at 2300 watts. No retracts and it weighs 7 lbs 10 oz. If it flys well I will consider retracts. I did change the gear, it is lighter and much less drag than stock.[image
Beautiful work. I wouldn't have known that you reshaped the fuse manually.
Where did you purchase the FAN? Links?
Thanks!
